Trio Stealth-10 Battery Replacement
  1. Trio Stealth-10 Battery Replacement, Back Panel: step 1, image 1 of 1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Battery Replacement, Battery: step 2, image 1 of 1
    • This step will require soldering. If you are unfamiliar with soldering then we recommend that you get help from another person or use the soldering guide made by Ifixit to help.
    • Solder the connections off for the battery.
  3. Trio Stealth-10 Battery Replacement: step 3, image 1 of 2 Trio Stealth-10 Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
    • Pull the cable away and clear from under the battery to avoid damage to the connection.
  4. Trio Stealth-10 Battery Replacement: step 4, image 1 of 1
    • Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
6 other people completed this guide.
Daniel Coleman
643 Reputation
5 Guides authored
UMass Dartmouth, Team 1-4, Miles Fall 2015 Member of UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 2,276
