Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: step 1, image 1 of 1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: step 2, image 1 of 1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: step 3, image 1 of 1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: step 4, image 1 of 1
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: step 5, image 1 of 1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
2 other people completed this guide.
Daniel Coleman
643 Reputation
5 Guides authored
UMass Dartmouth, Team 1-4, Miles Fall 2015 Member of UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 515
