Trio Stealth-10 Motherboard Replacement
  1. Trio Stealth-10 Motherboard Replacement, Back Panel: step 1, image 1 of 1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Motherboard Replacement, Speaker: step 2, image 1 of 1
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Motherboard Replacement: step 3, image 1 of 1
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
  4. Trio Stealth-10 Motherboard Replacement, Front-Facing/ Rear-Facing Camera: step 4, image 1 of 1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  5. Trio Stealth-10 Motherboard Replacement: step 5, image 1 of 1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  6. Trio Stealth-10 Motherboard Replacement: step 6, image 1 of 1
    • Remove the first layer of tape above camera cable connection slowly.
  7. Trio Stealth-10 Motherboard Replacement: step 7, image 1 of 1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
  8. Trio Stealth-10 Motherboard Replacement, Battery: step 8, image 1 of 1
    • This step will require soldering. If you are unfamiliar with soldering then we recommend that you get help from another person or use the soldering guide made by Ifixit to help.
    • Solder the connections off for the battery.
  9. Trio Stealth-10 Motherboard Replacement: step 9, image 1 of 2 Trio Stealth-10 Motherboard Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
    • Pull the cable away and clear from under the battery to avoid damage to the connection.
  10. Trio Stealth-10 Motherboard Replacement: step 10, image 1 of 1
    • Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
  11. Trio Stealth-10 Motherboard Replacement, Motherboard: step 11, image 1 of 1
    • Use your spudger to disconnect the screen/digitizer connection from the motherboard.
  12. Trio Stealth-10 Motherboard Replacement: step 12, image 1 of 2 Trio Stealth-10 Motherboard Replacement: step 12, image 2 of 2
    Buy
    • Use a pair of tweezers to grasp the screen/digitizer connection gently and remove each accordingly.
  13. Trio Stealth-10 Motherboard Replacement: step 13, image 1 of 1
    • Grasp the EDC tape with your tweezers and lift it off gently from the motherboard and set aside to be reused.
  14. Trio Stealth-10 Motherboard Replacement: step 14, image 1 of 2 Trio Stealth-10 Motherboard Replacement: step 14, image 2 of 2
    • Use a Phillips #0 to unscrew the 4mm screws from the motherboard fixture.
  15. Trio Stealth-10 Motherboard Replacement: step 15, image 1 of 1
    • Be sure that all the connections to the motherboard are disconnected. Proceed to remove the motherboard by slowly tilting it away from you and then lifting it straight up.
5 other people completed this guide.
Daniel Coleman
643 Reputation
5 Guides authored
UMass Dartmouth, Team 1-4, Miles Fall 2015 Member of UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,512
