Trio Stealth-Mini Screen Replacement
  1. Trio Stealth-Mini Screen Replacement, Battery: step 1, image 1 of 2 Trio Stealth-Mini Screen Replacement, Battery: step 1, image 2 of 2
    • Locate the indentation at the bottom of the device.
  2. Trio Stealth-Mini Screen Replacement: step 2, image 1 of 3 Trio Stealth-Mini Screen Replacement: step 2, image 2 of 3 Trio Stealth-Mini Screen Replacement: step 2, image 3 of 3
    • Pull on the indentation and take off the casing of the device.
  3. Trio Stealth-Mini Screen Replacement: step 3, image 1 of 2 Trio Stealth-Mini Screen Replacement: step 3, image 2 of 2
    • Remove the faulty battery and insert a replacement in its slot.
  4. Trio Stealth-Mini Screen Replacement, Screen: step 4, image 1 of 1
    • Remove the six 2.4 mm, Phillips #0 screws circled in the image.
  5. Trio Stealth-Mini Screen Replacement: step 5, image 1 of 1
    • Remove inner casing exposing the motherboard.
  6. Trio Stealth-Mini Screen Replacement: step 6, image 1 of 2 Trio Stealth-Mini Screen Replacement: step 6, image 2 of 2
    • Remove speakers by peeling back yelllow tape.
  7. Trio Stealth-Mini Screen Replacement: step 7, image 1 of 1
    • Remove ribbon cable on top of motherboard.
  8. Trio Stealth-Mini Screen Replacement: step 8, image 1 of 1
    • Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
  9. Trio Stealth-Mini Screen Replacement: step 9, image 1 of 1
    • Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
  10. Trio Stealth-Mini Screen Replacement: step 10, image 1 of 1
    • Verify that all screws are detached from screen.
  11. Trio Stealth-Mini Screen Replacement: step 11, image 1 of 1
    • Detach screen from main assembly.
Stewart Jenkins
207 Reputation
1 Guide authored
IUPUI, Team S1-G1, Harley Spring 2018 Member of IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
7 Members
6 Guides authored
One Comment
How can I do step 5? Do i need to push on the rectangle slots? It’s not very descriptive.
Nick “Blue” Wong - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 241
