Tristar Handmixer Gears Replacement
njjong
njjong and one other contributor
Last updated on December 29, 2016
30 minutes
Easy
Introduction
Go to step 1
Be aware that too much liquid might harm the engine of the product. For opening the product a spanner screwdriver is needed.
Tools
  1. Tristar Handmixer Gears Replacement, Gears: step 1, image 1 of 3 Tristar Handmixer Gears Replacement, Gears: step 1, image 2 of 3 Tristar Handmixer Gears Replacement, Gears: step 1, image 3 of 3
    • Remove all the screws with the spanner and Phillips screwdrivers.
  2. Tristar Handmixer Gears Replacement: step 2, image 1 of 3 Tristar Handmixer Gears Replacement: step 2, image 2 of 3 Tristar Handmixer Gears Replacement: step 2, image 3 of 3
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
  3. Tristar Handmixer Gears Replacement: step 3, image 1 of 3 Tristar Handmixer Gears Replacement: step 3, image 2 of 3 Tristar Handmixer Gears Replacement: step 3, image 3 of 3
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
  4. Tristar Handmixer Gears Replacement: step 4, image 1 of 2 Tristar Handmixer Gears Replacement: step 4, image 2 of 2
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
  5. Tristar Handmixer Gears Replacement: step 5, image 1 of 1
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
2 other people completed this guide.
3 Comments
where can I get replacement gears from?
lanz - Reply
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz -
On it now. Let's hope we don't need to buy Cheap-China-plastic. Ideal of course would be to find metal gears, that would last whole life (if not motor breaks).
I also need to find a manufacturer of cog drive train wheels, that could do custom made, tailored, because if you refurbish a vintage handmixer you need parts that are not manufactured or in circulation anymore.
Henry -
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 24
All Time: 1,761
