Troy-Bilt TB675 EC Air Filter Replacement
  1. Troy-Bilt TB675 EC Air Filter Replacement, Air Filter: step 1, image 1 of 1
    • Remove the air filter housing by turning the plastic screw counterclockwise with your hand.
  2. Troy-Bilt TB675 EC Air Filter Replacement, Remove the air filter that lays beneath the housing you removed in step 1: step 2, image 1 of 1
    • Remove the air filter that lays beneath the housing you removed in step 1.
    • It is good practice to inspect your air filter for tears or other defects. If defects are found it is best to replace the air filter rather than to clean it.
  3. Troy-Bilt TB675 EC Air Filter Replacement: step 3, image 1 of 1
    • Clean the air filter thoroughly by spraying compressed air through the filter.
    • Be sure to spray the compressed air away from you in order to prevent injury.
  4. Troy-Bilt TB675 EC Air Filter Replacement: step 4, image 1 of 2 Troy-Bilt TB675 EC Air Filter Replacement: step 4, image 2 of 2
    • Wipe all oil and water residue around the air filter casing with a paper towel or rag.
  5. Troy-Bilt TB675 EC Air Filter Replacement: step 5, image 1 of 1
    • Place the air filter and air filter casing back in its original position.
    • Be sure the air filter and housing are lined up correctly.
  6. Troy-Bilt TB675 EC Air Filter Replacement: step 6, image 1 of 1
    • Complete the maintenance by turning the screw clockwise with your hand until it is fully secured.
Finish Line
Brian Hall
110 Reputation
1 Guide authored
USF Tampa, Team 1-10, Donnelly Fall 2014 Member of USF Tampa, Team 1-10, Donnelly Fall 2014
USFT-DONNELLY-F14S1G10
1 Member
1 Guide authored
One Comment
I believe you may have missed the small detail of giving us a part #.
That would’ve been VERY helpful.
Mark Henry Cooney - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 2,433
