Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement
  1. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement, Panel: step 1, image 1 of 1
    • Flip the keyboard over.
  2. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: step 2, image 1 of 2 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: step 2, image 2 of 2
    • Remove the three JIS #1 screws from the back cover.
  3. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: step 3, image 1 of 2 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: step 3, image 2 of 2
    • Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
  4. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: step 4, image 1 of 1
    • Pull apart the two parts of the panel to expose the motherboard and keys.
  5. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement, Keys: step 5, image 1 of 2 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement, Keys: step 5, image 2 of 2
    • Use a plastic opening tool to pry off every key.
  6. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: step 6, image 1 of 3 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: step 6, image 2 of 3 Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: step 6, image 3 of 3
    • The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove.
    • Pull these keys to the side and up.
  7. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement, Led Lights: step 7, image 1 of 1
    • Since the LED lights are connected to every key, you will need to replace this whole part.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 492
