Tungsten E Battery Replacement
  1. Tungsten E Battery Replacement, Battery: step 1, image 1 of 1
  2. Tungsten E Battery Replacement: step 2, image 1 of 1
    • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
    • Caution: the battery is connected by two wires.
  3. Tungsten E Battery Replacement: step 3, image 1 of 1
    • Remove the battery
    • Caution: Be careful not to tear the wires when removing battery.
  4. Tungsten E Battery Replacement: step 4, image 1 of 1
    • Using a soldering iron, disconnect the battery wires.
    • Note: the wires are soldered to the board.
  5. Tungsten E Battery Replacement: step 5, image 1 of 1
    • Take replacement battery and solder the wires to the board.
    • Take care to match wire colors as before.
    • Use double sided tape to attach battery firmly to board.
Kathleen Hix
49 Reputation
2 Guides authored
Cal Poly, Team 13-22, Maness Winter 2010 Member of Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 23
All Time: 6,990
