Tungsten E Power Button Repair
  1. Tungsten E Power Button Repair, Tungsten E Disassembly: step 1, image 1 of 2 Tungsten E Power Button Repair, Tungsten E Disassembly: step 1, image 2 of 2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Power Button Repair: step 2, image 1 of 3 Tungsten E Power Button Repair: step 2, image 2 of 3 Tungsten E Power Button Repair: step 2, image 3 of 3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Tungsten E Power Button Repair: step 3, image 1 of 2 Tungsten E Power Button Repair: step 3, image 2 of 2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Power Button Repair: step 4, image 1 of 2 Tungsten E Power Button Repair: step 4, image 2 of 2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Power Button Repair: step 5, image 1 of 3 Tungsten E Power Button Repair: step 5, image 2 of 3 Tungsten E Power Button Repair: step 5, image 3 of 3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Power Button Repair: step 6, image 1 of 1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
  7. Tungsten E Power Button Repair, Tungsten E Power Button Repair: step 7, image 1 of 1
  8. Tungsten E Power Button Repair: step 8, image 1 of 1
    • On the motherboard, find the power button near the upper right corner.
    • Check for disconnection of the power button.
  9. Tungsten E Power Button Repair: step 9, image 1 of 1
    • Use soldering iron to reattach the damaged power button to the motherboard.
Kathleen Hix
49 Reputation
2 Guides authored
Cal Poly, Team 13-22, Maness Winter 2010 Member of Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 5,330
