Turtle Beach Ear Force P11 Speakers Replacement
Bhavesh Gandhi
Bhavesh Gandhi and 3 other contributors
Last updated on June 30, 2022
15 minutes
Moderate
Introduction
Go to step 1
The Turtle Beach P11 headset is equipped with two 50 mm diameter speakers with a frequency response between 20 Hz to 20 kHz which is same as the audible frequency range of the human ear. They have a bass boost fixed at +6 dB range at 50 Hz. There could be problems with the speaker such as inaudibility, crackling voice, distorted sounds etc. which cannot be fixed by suggested technical methods and thus require replacement of the speakers.
Tools
  1. Turtle Beach Ear Force P11 Speakers Replacement, Ear Cushion: step 1, image 1 of 1
    • Pinch the inner edge of the ear cushion from the bottom.
  2. Turtle Beach Ear Force P11 Speakers Replacement: step 2, image 1 of 1
    • Now slowly pull down the ear cushion as it completely separates from the speaker.
    • Carry out the pulling down action as slowly as possible or you might risk tearing the ear cushion otherwise
  3. Turtle Beach Ear Force P11 Speakers Replacement, Speakers: step 3, image 1 of 1
    • Remove the 4 screws on the red speaker cover.
    • It is recommended to use a #000 Philips Screw Driver
  4. Turtle Beach Ear Force P11 Speakers Replacement: step 4, image 1 of 2 Turtle Beach Ear Force P11 Speakers Replacement: step 4, image 2 of 2
    • Inspect the wires for damage as illustrated
  5. Turtle Beach Ear Force P11 Speakers Replacement: step 5, image 1 of 1
    • De-solder the speaker wires and remove the speaker.
    • Use low heat for de - soldering
  6. Turtle Beach Ear Force P11 Speakers Replacement: step 6, image 1 of 1
    • Solder the new speaker wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • In case you use a large amount of solder, use a solder wick to absorb the excess solder.
    • You can find more information on "How To Solder" here:How To Solder and Desolder Connections
4 other people completed this guide.
Bhavesh Gandhi
585 Reputation
3 Guides authored
IUPUI, Team 1-2, Wilson Fall 2015 Member of IUPUI, Team 1-2, Wilson Fall 2015
IUPUI-WILSON-F15S1G2
2 Members
6 Guides authored
6 Comments
can you fix mine contact me a jtrent238@outlook.com
jtrent238 - Reply
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Bhavesh Gandhi - Reply
If you look at step four you will see the black wire has a knot and a silver metal part. Well My wire has broken right there any advice? Please help!
Dev - Reply
Do you know where I can get the speakers from?
James Patrick - Reply
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
John - Reply
My problem is I don't know which wire with which one to solder. Can you help me?
Janan Babu - Reply
Past 24 Hours: 7
Past 7 Days: 12
Past 30 Days: 25
All Time: 3,853
