Turtle Beach Ear Force X12 Slide Adjustment Replacement
  1. Turtle Beach Ear Force X12 Slide Adjustment Replacement, Slide Adjustment: step 1, image 1 of 1
    • Remove the two 1.10 mm screws using the a T3 screwdriver.
  2. Turtle Beach Ear Force X12 Slide Adjustment Replacement: step 2, image 1 of 3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: step 2, image 2 of 3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool into the gap between the fabric and the plastic.
    • Make sure you have a firm grip, use the plastic opening tool to pry the two plastic pieces apart.
    • Be careful not to crack or brake the plastic pieces.
    • You should have two plastic pieces removed at the end. Replace them with new ones and reassemble.
Katha Patel
218 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Thompson Fall 2017 Member of USF Tampa, Team S1-G3, Thompson Fall 2017
USFT-THOMPSON-F17S1G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 538
