Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement
  1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: step 1, image 1 of 2 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: step 1, image 2 of 2
    • The microphone is a separate piece. So, unplug it from the headset.
  2. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: step 2, image 1 of 2 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: step 2, image 2 of 2
    • Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
  3. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: step 3, image 1 of 3 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: step 3, image 2 of 3 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: step 3, image 3 of 3
    • Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate.
    • Then slide the windscreen off of the microphone.
Andrew Rudnick
281 Reputation
2 Guides authored
Cal Poly, Team 17-36, Amido Winter 2015 Member of Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,754
