Turtle Beach Ear Force XO Seven Slide Adjustment Replacement
  1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: step 1, image 1 of 2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: step 1, image 2 of 2
    • Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
  2. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: step 2, image 1 of 2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: step 2, image 2 of 2
    • Insert the spudger into the gap between the leather and plastic.
    • After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
4 other people completed this guide.
Nancy Truong
375 Reputation
2 Guides authored
Cal Poly, Team 17-36, Amido Winter 2015 Member of Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 Members
12 Guides authored
7 Comments
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
jamesfalduto - Reply
I really don't want to buy another turtle beach headset
James did you ever find a solution because I have the same problem
Commandcorps - Reply
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
Jim Davis - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 4,313
