Turtle Beach REACT-R ABXY Buttons Replacement
  1. Turtle Beach REACT-R ABXY Buttons Replacement, Rear Case: step 1, image 1 of 3 Turtle Beach REACT-R ABXY Buttons Replacement, Rear Case: step 1, image 2 of 3 Turtle Beach REACT-R ABXY Buttons Replacement, Rear Case: step 1, image 3 of 3
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
  2. Turtle Beach REACT-R ABXY Buttons Replacement, Motherboard: step 2, image 1 of 3 Turtle Beach REACT-R ABXY Buttons Replacement, Motherboard: step 2, image 2 of 3 Turtle Beach REACT-R ABXY Buttons Replacement, Motherboard: step 2, image 3 of 3
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
  3. Turtle Beach REACT-R ABXY Buttons Replacement, ABXY Buttons: step 3, image 1 of 2 Turtle Beach REACT-R ABXY Buttons Replacement, ABXY Buttons: step 3, image 2 of 2
    • With the motherboard removed from the face plate, the buttons will be exposed from the inside.
    • The buttons are no longer secure and may fall out. To avoid this, make sure the controller is face down.
    • Gently remove the ABXY buttons.
Dodi Imam
637 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 40
All Time: 493
