Turtle Beach Recon Controller Front Buttons Replacement
  1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: step 1, image 1 of 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: step 1, image 2 of 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: step 1, image 3 of 3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
  2. Turtle Beach Recon Controller Front Buttons Replacement: step 2, image 1 of 3 Turtle Beach Recon Controller Front Buttons Replacement: step 2, image 2 of 3 Turtle Beach Recon Controller Front Buttons Replacement: step 2, image 3 of 3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
  3. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: step 3, image 1 of 2 Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: step 3, image 2 of 2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
  4. Turtle Beach Recon Controller Front Buttons Replacement: step 4, image 1 of 2 Turtle Beach Recon Controller Front Buttons Replacement: step 4, image 2 of 2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
  5. Turtle Beach Recon Controller Front Buttons Replacement: step 5, image 1 of 3 Turtle Beach Recon Controller Front Buttons Replacement: step 5, image 2 of 3 Turtle Beach Recon Controller Front Buttons Replacement: step 5, image 3 of 3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
  6. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: step 6, image 1 of 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: step 6, image 2 of 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: step 6, image 3 of 3
    • Gently remove front buttons from the face plate by hand.
Mary Goodrow
671 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 43
All Time: 470
