Introduction
After reading this guide, you will know how to swap out the gears and tube attached to the gears that are part of the arms that hold the propellers and motors of the drone.
Remove the 5 mm screws connecting each propeller to the rotating post using a Phillips #000 screwdriver.
Remove four 3 mm screws connecting the electronics to the frame using a Phillips #000 screwdriver.
Pull the two LED bars through the dust cover and remove the thin plastic dust cover from the drone.
Remove four 5 mm corner screws that secure both the receiving board and the motor arm using a Phillips #000 screwdriver.
The Front Left motor identified by the Red/Blue wires is a Standard(Clockwise) spinning motor, it pairs with a White A2 propeller.
The Front Right motor identified by the Black/White wires is a Reverse(CounterClockwise) spinning motor, it pairs with a White B2 propeller.
The Back Left motor identified by the Black/White wires is a Reverse(CounterClockwise) spinning motor, it pairs with a Black B1 propeller.
The Back Right motor identified by the Red/Blue wires is a Standard(Clockwise) spinning motor, it pairs with a Black A1 propeller.
The 4 bottom connectors receive the motor power cables that are Red/Yellow wire pairs from each motor. Counting the sockets 1-4 from left to right.
Front Right motor connects to socket 1.
Front Left motor connects to socket 2.
Rear Left motor connects to socket 3.
Rear Right motor connects to socket 4.
The Red/Green wire pairs from each motor power the LED to that branch, they connect to 4 of 6 sockets on the top of the receiving board. There is no sequence required.
The headlight LED, and underside LED bars connect to the remaining 2 sockets on the top of the receiving board. Again, no sequence is required. All LED Red/Black and Red/Green wire pairs connect to top of the receiving board.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to remove the silver nut from the bottom of the carbon tube.
4 other people completed this guide.
2 Comments
if i need to buy a new motor wheel where do i go online to buy them.
