UP! Plus 2 Extrusion Head Fan Replacement
  1. UP! Plus 2 Extrusion Head Fan Replacement, Remove fan cover: step 1, image 1 of 2 UP! Plus 2 Extrusion Head Fan Replacement, Remove fan cover: step 1, image 2 of 2
    • Remove the plastic cover that sits on the extruder, next to the fan, by lifting the latches in the back. The latches should lift right out.
  2. UP! Plus 2 Extrusion Head Fan Replacement, Remove fan: step 2, image 1 of 2 UP! Plus 2 Extrusion Head Fan Replacement, Remove fan: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, locate and remove the two 3mm screws on the top of the fan using a counter-clockwise rotation.
  3. UP! Plus 2 Extrusion Head Fan Replacement: step 3, image 1 of 2 UP! Plus 2 Extrusion Head Fan Replacement: step 3, image 2 of 2
    • Locate the fan connector, a 2-pin JST type, from the extruder board on the top of the extruder assembly and while firmly holding the plastic part of the connector, wiggle out the wire.
    • Gently lift the fan off and away from the module. The fan should easily fall out.
  4. UP! Plus 2 Extrusion Head Fan Replacement, Insert replacement fan: step 4, image 1 of 2 UP! Plus 2 Extrusion Head Fan Replacement, Insert replacement fan: step 4, image 2 of 2
    • Place the replacement fan on the extruder assembly in the right orientation.
    • Connect the cable make sure that it has a solid connection.
    • The fins of the fan should be directed to blow torwards the hot extruder shown in the picture, not away.
    • Secure the fan by screwing the top screws back into place in a clockwise rotation.
    • Finish by putting the plastic top back on.
valerie boyer
508 Reputation
4 Guides authored
Cal Poly, Team 14-31, Maness Fall 2014 Member of Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 Members
5 Guides authored
One Comment
I have a problem with my UP PLUS 3D printer and I really need your help. First printer started to stop in the middle of the printing, then got to the point where I wasn’t even able to connect it to my laptop (it didn’t recognize it) and now, when I press Print, before even slicing completes, the software crashes and I have to reopen (basically I can’t print anything as every time I try, same thing happens). The weird part is that sometimes I can adjust the bed, heat up extruder, extract or retract filament from software but the moment I press print, it dies. PLEASE HELP!!!
Nima - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 848
