UP! Plus 2 Spool Holder Replacement
  1. UP! Plus 2 Spool Holder Replacement, 3D print replacement spool holder: step 1, image 1 of 1
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: step 2, image 1 of 3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: step 2, image 2 of 3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: step 2, image 3 of 3
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. UP! Plus 2 Spool Holder Replacement, Remove spool holder: step 3, image 1 of 3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: step 3, image 2 of 3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: step 3, image 3 of 3
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  4. UP! Plus 2 Spool Holder Replacement, Replace spool holder: step 4, image 1 of 3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: step 4, image 2 of 3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: step 4, image 3 of 3
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
Finish Line
6 other people completed this guide.
valerie boyer
508 Reputation
4 Guides authored
Cal Poly, Team 14-31, Maness Fall 2014 Member of Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,238
