UTStarcom CDM8945vw Logic Board Replacement
  1. UTStarcom CDM8945vw Logic Board Replacement, Battery: step 1, image 1 of 1
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  2. UTStarcom CDM8945vw Logic Board Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. UTStarcom CDM8945vw Logic Board Replacement, Antenna: step 3, image 1 of 1
    • Identify the antenna. It is the extendable plastic component pictured here.
  4. UTStarcom CDM8945vw Logic Board Replacement: step 4, image 1 of 1
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
  5. UTStarcom CDM8945vw Logic Board Replacement: step 5, image 1 of 2 UTStarcom CDM8945vw Logic Board Replacement: step 5, image 2 of 2
    • The antenna should slide right out of the phone when finished.
  6. UTStarcom CDM8945vw Logic Board Replacement, Speaker: step 6, image 1 of 1
    • Remove the small rubber grommet using the plastic opening tool.
  7. UTStarcom CDM8945vw Logic Board Replacement: step 7, image 1 of 1
    • Remove five screws using a Phillips #00 screwdriver.
  8. UTStarcom CDM8945vw Logic Board Replacement: step 8, image 1 of 1
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
  9. UTStarcom CDM8945vw Logic Board Replacement: step 9, image 1 of 1
    • Remove the back piece of the outer case.
  10. UTStarcom CDM8945vw Logic Board Replacement: step 10, image 1 of 1
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  11. UTStarcom CDM8945vw Logic Board Replacement: step 11, image 1 of 2 UTStarcom CDM8945vw Logic Board Replacement: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  12. UTStarcom CDM8945vw Logic Board Replacement, Logic Board: step 12, image 1 of 1
    • Detach the highlighted piece from the logic board using a plastic opening tool.
  13. UTStarcom CDM8945vw Logic Board Replacement: step 13, image 1 of 2 UTStarcom CDM8945vw Logic Board Replacement: step 13, image 2 of 2
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
Bilal
1 Reputation
1 Guide authored
Cal Poly, Team 24-26, Regan Fall 2012 Member of Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 20
All Time: 404
