UTStarcom XV6700 Camera Replacement
  1. UTStarcom XV6700 Camera Replacement, Battery: step 1, image 1 of 1
    • Press the on/off button on the top to power the phone off.
  2. UTStarcom XV6700 Camera Replacement: step 2, image 1 of 1
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
  3. UTStarcom XV6700 Camera Replacement: step 3, image 1 of 3 UTStarcom XV6700 Camera Replacement: step 3, image 2 of 3 UTStarcom XV6700 Camera Replacement: step 3, image 3 of 3
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
  4. UTStarcom XV6700 Camera Replacement, Camera: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
  5. UTStarcom XV6700 Camera Replacement: step 5, image 1 of 2 UTStarcom XV6700 Camera Replacement: step 5, image 2 of 2
    • Use firm pressure to carefully pry off the cover with your fingers.
  6. UTStarcom XV6700 Camera Replacement: step 6, image 1 of 1
    • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
  7. UTStarcom XV6700 Camera Replacement: step 7, image 1 of 1
    • Gently pry off the camera flash circuit board with the spudger.
  8. UTStarcom XV6700 Camera Replacement: step 8, image 1 of 1
    • Gently pry off the camera with the spudger.
Jesse Walker
201 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 306
