Ubiquiti 48 port switch (US 48 G1) power supply replacement
  1. Ubiquiti 48 port switch (US 48 G1) power supply replacement, Open the Switch: step 1, image 1 of 1
    • Identify the four screws (two at the back, two at the bottom) holding the switch closed. One is hidden behind a sticker.
    • You do not need to remove the rack brackets
    • Use a PZ2 screwdriver to remove the screws
    • Slide the lid a short distance towards the front to open the switch.
  2. Ubiquiti 48 port switch (US 48 G1) power supply replacement, Identify the broken power supply: step 2, image 1 of 3 Ubiquiti 48 port switch (US 48 G1) power supply replacement, Identify the broken power supply: step 2, image 2 of 3 Ubiquiti 48 port switch (US 48 G1) power supply replacement, Identify the broken power supply: step 2, image 3 of 3
    • Identify the power supply. It is the yellow separate board at the bottom.
    • There may be burn marks on the power supply from the failure.
    • Remove it from the switch (4 screws, PZ2)
    • Save the power supply and screws. You will need them later.
  3. Ubiquiti 48 port switch (US 48 G1) power supply replacement, Ready the replacement power supply: step 3, image 1 of 2 Ubiquiti 48 port switch (US 48 G1) power supply replacement, Ready the replacement power supply: step 3, image 2 of 2
    • Unbox the replacement Powersupply
    • Unscrew the two screws at the front, and the two at the back to remove the top metal screen
    • Finally removed the two back screws to free the board from the bottom metal screen
  4. Ubiquiti 48 port switch (US 48 G1) power supply replacement, Install new power supply: step 4, image 1 of 1
    • Insert the replacement Powersupply in the switch, and secure it with the original 4 screws
    • Dimensions of the replacement power supply should be identical to the original one.
    • The main power connector should fit on the new power supply.
  5. Ubiquiti 48 port switch (US 48 G1) power supply replacement, Connect the 24V leads: step 5, image 1 of 1
    • Unsolder the 24v leads from the old power supply.
    • Identify the positive and negative output on the new power supply. On this one, positive is at the bottom of the picture.
    • Solder in the 24v leads on the new power supply
    • Solder in the blue (+) lead on the bottom of the output connector
    • Solder in the black (-) lead on the top of the output connector
    • Alternatively, get a proper connector that fits on the power supply.
    • Finally, connect the 24V on the main board
To reassemble your device, close the lid and secure the four screws.
Pehr Söderman
146 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 42
All Time: 777
