Ukulele Tuning Pegs Replacement
  1. Ukulele Tuning Pegs Replacement, Tuning Pegs: step 1, image 1 of 3 Ukulele Tuning Pegs Replacement, Tuning Pegs: step 1, image 2 of 3 Ukulele Tuning Pegs Replacement, Tuning Pegs: step 1, image 3 of 3
    • Place the ukulele on a flat surface.
    • Completely unwind the string connected to the broken tuning peg by turning the black knob clockwise.
  2. Ukulele Tuning Pegs Replacement: step 2, image 1 of 2 Ukulele Tuning Pegs Replacement: step 2, image 2 of 2
    • Place the ukulele string in between your index finger and thumb.
    • Pull the ukulele string from the hole on the tuning peg.
  3. Ukulele Tuning Pegs Replacement: step 3, image 1 of 3 Ukulele Tuning Pegs Replacement: step 3, image 2 of 3 Ukulele Tuning Pegs Replacement: step 3, image 3 of 3
    • Turn the ukulele over, and note the placement of the screws attaching the tuning pegs to the head of the ukulele.
    • Using the PH00 screwdriver, turn the first screw counter clockwise to loosen.
  4. Ukulele Tuning Pegs Replacement: step 4, image 1 of 2 Ukulele Tuning Pegs Replacement: step 4, image 2 of 2
    • Using the PH00 screwdriver, turn the second screw counter clockwise to loosen.
    • Set the screws aside to use for later.
  5. Ukulele Tuning Pegs Replacement: step 5, image 1 of 3 Ukulele Tuning Pegs Replacement: step 5, image 2 of 3 Ukulele Tuning Pegs Replacement: step 5, image 3 of 3
    • Place the tuning peg knob in between your thumb and index finger.
    • Pull the old tuning peg completely off the ukulele.
  6. Ukulele Tuning Pegs Replacement: step 6, image 1 of 3 Ukulele Tuning Pegs Replacement: step 6, image 2 of 3 Ukulele Tuning Pegs Replacement: step 6, image 3 of 3
    • Have the new tuning peg clean and ready to replace the old tuning peg.
    • Place the new tuning peg onto the hole in the fret board.
    • Make sure the two holes that the two screws came out of are lined up to the two holes on the back of the fret board.
  7. Ukulele Tuning Pegs Replacement: step 7, image 1 of 3 Ukulele Tuning Pegs Replacement: step 7, image 2 of 3 Ukulele Tuning Pegs Replacement: step 7, image 3 of 3
    • Place one of the screws onto the PH00 screwdriver tip.
    • Line up the screw to a hole in the tuning peg and tighten by turning the PH00 screwdriver clockwise.
  8. Ukulele Tuning Pegs Replacement: step 8, image 1 of 3 Ukulele Tuning Pegs Replacement: step 8, image 2 of 3 Ukulele Tuning Pegs Replacement: step 8, image 3 of 3
    • Place the other screw onto the PH00 screwdriver tip.
    • Line up the screw to the remaining hole and tighten it by turning the PH00 screwdriver clockwise.
    • Tighten screws just until the screws are no longer loose. If you over tighten the screws, you might crack the wood.
  9. Ukulele Tuning Pegs Replacement: step 9, image 1 of 3 Ukulele Tuning Pegs Replacement: step 9, image 2 of 3 Ukulele Tuning Pegs Replacement: step 9, image 3 of 3
    • Turn the ukulele on its side.
  10. Ukulele Tuning Pegs Replacement: step 10, image 1 of 3 Ukulele Tuning Pegs Replacement: step 10, image 2 of 3 Ukulele Tuning Pegs Replacement: step 10, image 3 of 3
    • Insert the string into the hole of the tuning peg
    • Continue holding the string, and turn the black knob of the tuning peg counter-clockwise until the string is correctly tuned.
  11. Ukulele Tuning Pegs Replacement: step 11, image 1 of 1
    • Enjoy your refurbished ukulele.
Finish Line
Seth Talkington
193 Reputation
1 Guide authored
UC Davis, Team S2-G3, Andersen Winter 2020 Member of UC Davis, Team S2-G3, Andersen Winter 2020
UCD-ANDERSEN-W20S2G3
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 52
All Time: 4,195
