UnBranded UB-15MS10 Back Panel Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. UnBranded UB-15MS10 Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
  2. UnBranded UB-15MS10 Back Panel Replacement: step 2, image 1 of 1
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
  3. UnBranded UB-15MS10 Back Panel Replacement: step 3, image 1 of 2 UnBranded UB-15MS10 Back Panel Replacement: step 3, image 2 of 2
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
  4. UnBranded UB-15MS10 Back Panel Replacement: step 4, image 1 of 1
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
  5. UnBranded UB-15MS10 Back Panel Replacement: step 5, image 1 of 1
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
8 other people completed this guide.
Andrea Hammans
579 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Fall 2015 Member of IUPUI, Team 2-1, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G1
3 Members
3 Guides authored
1 Guide Comment
Thanks you, work good for me.
Cesar Alvarez - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,389
