Unfasten Battery
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Unfasten Battery, Unfasten the bottom cable shield: step 1, image 1 of 2 Unfasten Battery, Unfasten the bottom cable shield: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the bottom cable shield to the logic board.
  2. Unfasten Battery, Remove the bottom cable shield: step 2, image 1 of 3 Unfasten Battery, Remove the bottom cable shield: step 2, image 2 of 3 Unfasten Battery, Remove the bottom cable shield: step 2, image 3 of 3
    • Use tweezers or your fingers to remove the bottom cable shield.
  3. Unfasten Battery, Disconnect the battery: step 3, image 1 of 2 Unfasten Battery, Disconnect the battery: step 3, image 2 of 2
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
Chayton Ritter
24,958 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
15,932 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 69
