Uniden D1483-3BK Circuit Board/Screen Replacement
  1. Uniden D1483-3BK Circuit Board/Screen Replacement, Battery: step 1, image 1 of 1
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Circuit Board/Screen Replacement: step 2, image 1 of 2 Uniden D1483-3BK Circuit Board/Screen Replacement: step 2, image 2 of 2
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Circuit Board/Screen Replacement: step 3, image 1 of 1
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: step 4, image 1 of 2 Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: step 4, image 2 of 2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Circuit Board/Screen Replacement: step 5, image 1 of 3 Uniden D1483-3BK Circuit Board/Screen Replacement: step 5, image 2 of 3 Uniden D1483-3BK Circuit Board/Screen Replacement: step 5, image 3 of 3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Circuit Board/Screen Replacement: step 6, image 1 of 2 Uniden D1483-3BK Circuit Board/Screen Replacement: step 6, image 2 of 2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Circuit Board/Screen Replacement: step 7, image 1 of 2 Uniden D1483-3BK Circuit Board/Screen Replacement: step 7, image 2 of 2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Circuit Board/Screen Replacement, Circuit Board/Screen: step 8, image 1 of 1
    • Set the circuit board on the table with the screen facing down.
  9. Uniden D1483-3BK Circuit Board/Screen Replacement: step 9, image 1 of 1
    • Using the desoldering braid and soldering iron, remove the solder around the cable for the speaker.
    • When installing the new board, use the soldering iron and solder to reattach the speaker cables.
6 other people completed this guide.
Arbitrary Name
1,083 Reputation
4 Guides authored
Penn State, Team 1-8, Kaschak Winter 2015 Member of Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 308
