Uniden D1688 Handheld Replacement
  1. Uniden D1688 Handheld Replacement, Uniden D1688 Handheld Replacement: step 1, image 1 of 2 Uniden D1688 Handheld Replacement, Uniden D1688 Handheld Replacement: step 1, image 2 of 2
    • Slide the battery cover off of the handset, and unplug the battery.
  2. Uniden D1688 Handheld Replacement: step 2, image 1 of 1
    • Remove the battery, and unscrew the two screws(Head Size: 4mm Length: 8.6 mm).
  3. Uniden D1688 Handheld Replacement: step 3, image 1 of 1
    • Use spudger to separate the phone shell.
  4. Uniden D1688 Handheld Replacement: step 4, image 1 of 1
    • Unscrew the two screws(Head Size: 4mm Length: 8.6mm) on the bottom shell keeping the speaker locking pin in place.
  5. Uniden D1688 Handheld Replacement: step 5, image 1 of 1
    • Remove screw (4mm head,8.6mm length) from circuit board.
  6. Uniden D1688 Handheld Replacement: step 6, image 1 of 1
    • Remove the rubber keyboard layer.
  7. Uniden D1688 Handheld Replacement: step 7, image 1 of 1
    • Remove plastic buttons from outer shell.
justin
419 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 6
All Time: 337
