Uniden Dect 6.0 Display Replacement
  1. Uniden Dect 6.0 Display Replacement, Battery: step 1, image 1 of 1
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Display Replacement: step 2, image 1 of 1
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Display Replacement: step 3, image 1 of 1
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Display Replacement, Keyboard: step 4, image 1 of 2 Uniden Dect 6.0 Display Replacement, Keyboard: step 4, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Display Replacement: step 5, image 1 of 1
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Display Replacement: step 6, image 1 of 1
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
  7. Uniden Dect 6.0 Display Replacement, Gel Casing: step 7, image 1 of 1
    • To better access the screen, remove the loose gel casing that sits under the keyboard.
  8. Uniden Dect 6.0 Display Replacement: step 8, image 1 of 1
    • Lift out the attached motherboard piece and turn it sideways to access the side of the phone.
    • Potential for device damage: Use caution to avoid severing the wires that connect the motherboard to the phone.
  9. Uniden Dect 6.0 Display Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Gently use the tweezers to access the motherboard panel and lift it straight up.
3 other people completed this guide.
Megan Lawrence
534 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 6,450
