Uniden EXP 371 Antenna Replacement
  1. Uniden EXP 371 Antenna Replacement, Uniden EXP 371 Teardown: step 1, image 1 of 1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Antenna Replacement: step 2, image 1 of 2 Uniden EXP 371 Antenna Replacement: step 2, image 2 of 2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Antenna Replacement: step 3, image 1 of 2 Uniden EXP 371 Antenna Replacement: step 3, image 2 of 2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Antenna Replacement: step 4, image 1 of 3 Uniden EXP 371 Antenna Replacement: step 4, image 2 of 3 Uniden EXP 371 Antenna Replacement: step 4, image 3 of 3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
  5. Uniden EXP 371 Antenna Replacement, Antenna: step 5, image 1 of 2 Uniden EXP 371 Antenna Replacement, Antenna: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • After following the teardown guide. Take the bottom case and locate the antenna at the top of the phone.
    • Lift the bottom of the the antenna with the aid of a tool (these tweezers work well) and push the antenna inside the phone to remove it.
    • To reassemble the phone, follow the steps in the reverse order.
Eric Rodrigues
343 Reputation
3 Guides authored
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,279
