Uniden EXP 371 Keypad Replacement
  1. Uniden EXP 371 Keypad Replacement, Dissassemble the Uniden EXP 371 phone: step 1, image 1 of 1
    • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  2. Uniden EXP 371 Keypad Replacement: step 2, image 1 of 3 Uniden EXP 371 Keypad Replacement: step 2, image 2 of 3 Uniden EXP 371 Keypad Replacement: step 2, image 3 of 3
    • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  3. Uniden EXP 371 Keypad Replacement: step 3, image 1 of 2 Uniden EXP 371 Keypad Replacement: step 3, image 2 of 2
    • Remove the motherboard once the screws holding it in place are undone.
    • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  4. Uniden EXP 371 Keypad Replacement: step 4, image 1 of 1
    • After the rubber pad is removed remove the dial pad (buttons) from the phone.
  5. Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: step 5, image 1 of 2 Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: step 5, image 2 of 2
    • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
    • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  6. Uniden EXP 371 Keypad Replacement, Order a New Dial Pad: step 6, image 1 of 1
Lucas Mohsen
101 Reputation
1 Guide authored
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 154
