Uniden Guardian G955 Battery Replacement
  1. Uniden Guardian G955 Battery  Replacement, Battery: step 1, image 1 of 1
    • First, remove four 6.1 mm screws from your monitor using a J1 Phillips head screwdriver.
  2. Uniden Guardian G955 Battery  Replacement: step 2, image 1 of 1
    • Carefully, use a metal spudger to open the case starting from any corner.
    • Slowly slide the spudger along the inside edge of the case.
  3. Uniden Guardian G955 Battery  Replacement: step 3, image 1 of 2 Uniden Guardian G955 Battery  Replacement: step 3, image 2 of 2
    • Remove the two 6.1 mm screws from the black fastener using a screwdriver.
    • Remove the black fastener.
  4. Uniden Guardian G955 Battery  Replacement: step 4, image 1 of 2 Uniden Guardian G955 Battery  Replacement: step 4, image 2 of 2
    • Disconnect the head of the cable attached to the motherboard by pressing on the outer edge of the cable and sliding it out.
  5. Uniden Guardian G955 Battery  Replacement: step 5, image 1 of 2 Uniden Guardian G955 Battery  Replacement: step 5, image 2 of 2
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Remove the battery from the case by sliding a halberd spudger below it. (note: the spudger shown is metal, to ensure proper safety, utilize a nylon or plastic spudger.)
Sundus Al Shibani
180 Reputation
1 Guide authored
USF Tampa, Team 1-1, Nance Fall 2016 Member of USF Tampa, Team 1-1, Nance Fall 2016
USFT-NANCE-F16S1G1
3 Members
8 Guides authored
4 Guide Comments
The instructions and illustrations are fine, but there is NO information on how to obtain a replacement battery. I have searched without any luck.
Ricaedo Garcia - Reply Share
Hello, I sure hope I can get a answer on this, Ricaedo Garcia was you able to find a replacement battery for yours. I been searching for one and no luck. Thank you
Kathy - Share
I’m going to try using this battery: YK843553-Battery-for-UNIDEN-UBW2101C-Camera-UBWC21-1250mAh
I think it will work. The connector and voltage are the same.
George Scott - Reply Share
George Scott: Did that battery work satisfactorily?
PhBob - - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 33
All Time: 6,287
