Uniden TCX905 Button Keypad Cleaning Guide
  1. Uniden TCX905 Button Keypad Cleaning Guide, Battery Cover: step 1, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide, Battery Cover: step 1, image 2 of 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Button Keypad Cleaning Guide, Battery Pack: step 2, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide, Battery Pack: step 2, image 2 of 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Button Keypad Cleaning Guide, Back Shell: step 3, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide, Back Shell: step 3, image 2 of 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Button Keypad Cleaning Guide: step 4, image 1 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 4, image 2 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 4, image 3 of 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Button Keypad Cleaning Guide: step 5, image 1 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 5, image 2 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 5, image 3 of 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Button Keypad Cleaning Guide, Circuit Board: step 6, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide, Circuit Board: step 6, image 2 of 2
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Uniden TCX905 Button Keypad Cleaning Guide: step 7, image 1 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 7, image 2 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 7, image 3 of 3
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
  8. Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: step 8, image 1 of 3 Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: step 8, image 2 of 3 Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: step 8, image 3 of 3
    • Remove the white plastic sheet covering the button pad with your fingers
    • Gently remove the silicon button pad
  9. Uniden TCX905 Button Keypad Cleaning Guide: step 9, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide: step 9, image 2 of 2
    • Wet one end of the cotton swab with water and clean button pad as needed
    • Repeat process with multiple cotton swabs if needed
    • Dry the button pad with a clean, soft rag before replacing
Gary Pence
807 Reputation
8 Guides authored
Clemson, Team 1-1, Benson Spring 2014 Member of Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 976
