Uniden UTAB71 Battery Replacement
  1. Uniden UTAB71 Battery Replacement, Battery: step 1, image 1 of 2 Uniden UTAB71 Battery Replacement, Battery: step 1, image 2 of 2
    • Use a plastic opening tool to undo the clips that attach the two halves of the tablet.
    • Be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Battery Replacement: step 2, image 1 of 1
    • Lift off the tape that holds the speaker wires to the battery
    • Leave the tape off to the side
  3. Uniden UTAB71 Battery Replacement: step 3, image 1 of 1
    • Use a soldering tool to disconnect the two wires (red and black) that connect the battery to the motherboard
    • Note the placement of each colored wire in the motherboard
    • If you have no experience in soldering, please follow this guide
  4. Uniden UTAB71 Battery Replacement: step 4, image 1 of 2 Uniden UTAB71 Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    iOpener
    $14.99
    Buy
    • Use a credit card to lift the battery off the back of the tablet
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery attached to the back panel with adhesive. You may need to use a heated iOpener to loosen the adhesive and remove the battery.
Ryan Jewell
431 Reputation
4 Guides authored
UMass Dartmouth, Team 5-4, Martin Fall 2016 Member of UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 446
