Uniden UTAB71 Camera Replacement
  1. Uniden UTAB71 Camera Replacement, Camera: step 1, image 1 of 2 Uniden UTAB71 Camera Replacement, Camera: step 1, image 2 of 2
    • Use a plastic pry tool to separate the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Camera Replacement: step 2, image 1 of 2 Uniden UTAB71 Camera Replacement: step 2, image 2 of 2
    • Use a credit card to lift the battery off the back of the tablet.
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
  3. Uniden UTAB71 Camera Replacement: step 3, image 1 of 1
    • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
  4. Uniden UTAB71 Camera Replacement: step 4, image 1 of 3 Uniden UTAB71 Camera Replacement: step 4, image 2 of 3 Uniden UTAB71 Camera Replacement: step 4, image 3 of 3
    • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
    • Place the plastic pry tool under the camera component and lift it off the tablet.
Ryan Jewell
431 Reputation
4 Guides authored
UMass Dartmouth, Team 5-4, Martin Fall 2016 Member of UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 260
