Unnecto Drone M Earpiece Speaker Replacement
  1. Unnecto Drone M Earpiece Speaker Replacement, Unnecto Drone M Disassembly: step 1, image 1 of 2 Unnecto Drone M Earpiece Speaker Replacement, Unnecto Drone M Disassembly: step 1, image 2 of 2
    • Place the phone facedown on a cleared work area
    • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
  2. Unnecto Drone M Earpiece Speaker Replacement: step 2, image 1 of 1
    • Grip the top right corner of the battery.
    • Remove the battery by pulling it outwards.
  3. Unnecto Drone M Earpiece Speaker Replacement: step 3, image 1 of 1
    • Remove the four screws on the back of the phone using a Philips 000 screwdriver
  4. Unnecto Drone M Earpiece Speaker Replacement: step 4, image 1 of 1
    • Separate the frame evenly using a plastic opening tool.
    • Be careful, as the frame is thin and can break easily.
  5. Unnecto Drone M Earpiece Speaker Replacement: step 5, image 1 of 2 Unnecto Drone M Earpiece Speaker Replacement: step 5, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
  6. Unnecto Drone M Earpiece Speaker Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
  7. Unnecto Drone M Earpiece Speaker Replacement: step 7, image 1 of 1
    • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
    • The white circuit is flimsy and securely glued to the frame.
  8. Unnecto Drone M Earpiece Speaker Replacement: step 8, image 1 of 2 Unnecto Drone M Earpiece Speaker Replacement: step 8, image 2 of 2
    • Set aside the circuit board from the screen protector.
  9. Unnecto Drone M Earpiece Speaker Replacement, Earpiece Speaker: step 9, image 1 of 2 Unnecto Drone M Earpiece Speaker Replacement, Earpiece Speaker: step 9, image 2 of 2
    Buy
    • Peel back the speaker using fine-tipped tweezers
    • Use caution when removing the earpiece speaker
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 180
