Untracked Bifold Door Pin Replacement
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: step 1, image 1 of 1
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: step 2, image 1 of 1
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: step 3, image 1 of 1
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: step 4, image 1 of 2 Untracked Bifold Door Pin Replacement: step 4, image 2 of 2
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: step 5, image 1 of 1
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: step 6, image 1 of 1
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: step 7, image 1 of 1
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: step 8, image 1 of 1
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: step 9, image 1 of 1
    • When completed, the bifold doors should close and be positioned within the tracking.
Catelyn Carpenter
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 42
All Time: 1,485
