Upper Component Bracket Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Upper Component Bracket Removal, Remove the upper component bracket: step 1, image 1 of 2 Upper Component Bracket Removal, Remove the upper component bracket: step 1, image 2 of 2
    • Carefully peel the LCD buffer tape up off of the upper component bracket.
  2. Upper Component Bracket Removal: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket.
    • Three 1.4 mm-long screws
    • Two 1.9 mm-long screws
  3. Upper Component Bracket Removal: step 3, image 1 of 3 Upper Component Bracket Removal: step 3, image 2 of 3 Upper Component Bracket Removal: step 3, image 3 of 3
    • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
    • Remove the upper component bracket.
    • You may need to peel the upper component bracket off of some tape securing it to the logic board.
Robert Boyd
31,676 Reputation
94 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 64
