Urge Basics Soundbrick Speaker Woofer Replacement
  1. Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: step 1, image 1 of 3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: step 1, image 2 of 3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: step 1, image 3 of 3
    • Flip the speaker upside down.
    • Unscrew the middle screw with a Philips #1 screwdriver.
  2. Urge Basics Soundbrick Speaker Woofer Replacement: step 2, image 1 of 2 Urge Basics Soundbrick Speaker Woofer Replacement: step 2, image 2 of 2
    • Peel off the two gray tabs to expose the four inner Philips #1 screws.
  3. Urge Basics Soundbrick Speaker Woofer Replacement: step 3, image 1 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 3, image 2 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 3, image 3 of 3
    • Unscrew all four screws with a Philips #1 screwdriver.
    • The screws are deep and can be difficult to take out.
  4. Urge Basics Soundbrick Speaker Woofer Replacement: step 4, image 1 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 4, image 2 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 4, image 3 of 3
    • Flip the speaker so that the ports are facing up.
    • Unfold the speaker's cover away from the body.
  5. Urge Basics Soundbrick Speaker Woofer Replacement: step 5, image 1 of 2 Urge Basics Soundbrick Speaker Woofer Replacement: step 5, image 2 of 2
    • Remove the two Phillips #1 screws found on each side of the battery compartment.
    • Removal of battery compartment is necessary to prevent electric shock when replacing the woofer.
  6. Urge Basics Soundbrick Speaker Woofer Replacement: step 6, image 1 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 6, image 2 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 6, image 3 of 3
    • Disconnect the battery connectors attached to the circuit board by unplugging them.
  7. Urge Basics Soundbrick Speaker Woofer Replacement: step 7, image 1 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 7, image 2 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 7, image 3 of 3
    • Disconnect the ribbon cable from the battery by carefully pulling it out.
    • Remove the battery compartment.
  8. Urge Basics Soundbrick Speaker Woofer Replacement: step 8, image 1 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 8, image 2 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 8, image 3 of 3
    • Disconnect the adjacent connector from the main circuit board.
  9. Urge Basics Soundbrick Speaker Woofer Replacement: step 9, image 1 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 9, image 2 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 9, image 3 of 3
    • Disconnect the woofer's two connectors from the main circuit board.
  10. Urge Basics Soundbrick Speaker Woofer Replacement: step 10, image 1 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 10, image 2 of 3 Urge Basics Soundbrick Speaker Woofer Replacement: step 10, image 3 of 3
    • Remove the two Phillips #1 screws keeping each woofer in place.
    • Carefully remove the woofers and replace them with new ones.
Itzel Urueta
125 Reputation
1 Guide authored
UC Davis, Team S2-G4, Cole Spring 2017 Member of UC Davis, Team S2-G4, Cole Spring 2017
UCD-COLE-S17S2G4
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 890
