V-Moda Crossfade Wireless Headphones Battery Replacement
  1. V-Moda Crossfade Wireless Headphones Battery Replacement, Battery: step 1, image 1 of 3 V-Moda Crossfade Wireless Headphones Battery Replacement, Battery: step 1, image 2 of 3 V-Moda Crossfade Wireless Headphones Battery Replacement, Battery: step 1, image 3 of 3
    • The battery is housed in the left half of the headphones (the side with the micro-USB port).
    • Grasp the left ear cup cushion with your fingers and gently pull towards the center of the earcup. This will release the cushion from the tabs that are holding it in place.
    • Gently pull the ear cup from the rest of the tabs that hold it in place.
    • Remove the ear cup cushion.
    • To reinstall the cushion, align the ear up to the headphones. Squeeze around the perimeter of the cushions to snap the ear cup in place.
  2. V-Moda Crossfade Wireless Headphones Battery Replacement: step 2, image 1 of 2 V-Moda Crossfade Wireless Headphones Battery Replacement: step 2, image 2 of 2
    • Remove the six 10.1 mm Phillips screws securing the left headphone's speaker plate.
    • Insert an opening pick in the seam between the left headphone's plastic housing and metal rim.
    • Slide the pick along the seam and twist gently to loosen the speaker plate.
  3. V-Moda Crossfade Wireless Headphones Battery Replacement: step 3, image 1 of 2 V-Moda Crossfade Wireless Headphones Battery Replacement: step 3, image 2 of 2
    • Grasp the metal rim with your fingers and gently pull it away from the headphone cup.
    • Do not attempt to remove the speaker plate. The speaker is connected with very delicate wires.
  4. V-Moda Crossfade Wireless Headphones Battery Replacement: step 4, image 1 of 2 V-Moda Crossfade Wireless Headphones Battery Replacement: step 4, image 2 of 2
    • As you work on the headphones, be careful not to stress the delicate speaker cable.
    • The battery is a Kanyo 350 mAh pack measuring 34mm x 24mm x 5mm.
    • The battery area can fit a battery that's up to 39.4mm x 31mm x 5mm.
    • There are reports that V-Moda has been using different sized battery packs. Before you order a replacement battery, be sure to measure carefully.
    • You can replace the battery with any standard two-wire lithium-ion polymer pack that would fit in the space.
  5. V-Moda Crossfade Wireless Headphones Battery Replacement: step 5, image 1 of 2 V-Moda Crossfade Wireless Headphones Battery Replacement: step 5, image 2 of 2
    • Remove the two 5.9 mm Phillips screws securing the micro-USB port.
    • Use the flat end of a spudger to pry up and loosen the board from the two screw posts.
  6. V-Moda Crossfade Wireless Headphones Battery Replacement: step 6, image 1 of 2 V-Moda Crossfade Wireless Headphones Battery Replacement: step 6, image 2 of 2
    • Carefully flip the board over and note the two solder joints connected to the battery cables.
    • De-solder the two solder joints and replace the battery. You will have to re-solder the battery to these contact points.
    • Alternatively, cut the wires one-by-one before you desolder them. This will help prevent unintentional short circuitry.
    • Be very careful not to short the battery wires. Doing so may overheat and ignite the battery.
    • Be sure to maintain the correct battery polarity when you re-solder the wires.
    • The back of the board is shown for reference.
9 other people completed this guide.
Arthur Shi
258,910 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,076 Guides authored
14 Comments
any link to get the right battery Mr. Arthur?
florescristobal14 - Reply
I have not tried it, but a li-po pack like this should work, while even giving you a battery capacity boost. Again, you would need to solder the battery contacts on.
Arthur Shi -
Hey just finished completing my battery replacement with flying colors thx for the guide and link to the replacement battery my man.
Squeezy Jibbs - Reply
I’m glad to hear it worked out for you!
Arthur Shi -
I need to clean the underside of the grill that’s over the speaker… Is there any way to remove the grill without damaging it??
Gabriel - Reply
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 158
All Time: 13,119
