VENSTAR Taco Disassembly
  1. VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: step 1, image 1 of 3 VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: step 1, image 2 of 3 VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: step 1, image 3 of 3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Disassembly: step 2, image 1 of 2 VENSTAR Taco Disassembly: step 2, image 2 of 2
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. VENSTAR Taco Disassembly: step 3, image 1 of 2 VENSTAR Taco Disassembly: step 3, image 2 of 2
    Tool used on this step:
    Phillips #0 Screwdriver
    $5.49
    Buy
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. VENSTAR Taco Disassembly: step 4, image 1 of 2 VENSTAR Taco Disassembly: step 4, image 2 of 2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. VENSTAR Taco Disassembly: step 5, image 1 of 2 VENSTAR Taco Disassembly: step 5, image 2 of 2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 523
