VENSTAR Taco Microphone Replacement Replacement
  1. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: step 1, image 1 of 3 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: step 1, image 2 of 3 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: step 1, image 3 of 3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Microphone Replacement Replacement: step 2, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 2, image 2 of 2
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. VENSTAR Taco Microphone Replacement Replacement: step 3, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 3, image 2 of 2
    Tool used on this step:
    Phillips #0 Screwdriver
    $5.49
    Buy
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. VENSTAR Taco Microphone Replacement Replacement: step 4, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 4, image 2 of 2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. VENSTAR Taco Microphone Replacement Replacement: step 5, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 5, image 2 of 2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
  6. VENSTAR Taco Microphone Replacement Replacement, Logic Board Replacement: step 6, image 1 of 1
    • Remove the rubber covering from the buttons.
  7. VENSTAR Taco Microphone Replacement Replacement: step 7, image 1 of 3 VENSTAR Taco Microphone Replacement Replacement: step 7, image 2 of 3 VENSTAR Taco Microphone Replacement Replacement: step 7, image 3 of 3
    • Remove the black fabric covering the logic board.
  8. VENSTAR Taco Microphone Replacement Replacement: step 8, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 8, image 2 of 2
    • Move the battery out of the way of the connector.
  9. VENSTAR Taco Microphone Replacement Replacement: step 9, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 9, image 2 of 2
    • Undo the connector of the flat white ribbon between the switches and the logic board.
  10. VENSTAR Taco Microphone Replacement Replacement: step 10, image 1 of 1
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
  11. VENSTAR Taco Microphone Replacement Replacement: step 11, image 1 of 3 VENSTAR Taco Microphone Replacement Replacement: step 11, image 2 of 3 VENSTAR Taco Microphone Replacement Replacement: step 11, image 3 of 3
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
  12. VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: step 12, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: step 12, image 2 of 2
    • Below the logic board, the small black microphone is resting within the case.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 285
