VTech Baby's Learning Laptop Buttons Replacement
  1. VTech Baby's Learning Laptop Buttons Replacement, Battery and Rear Panel: step 1, image 1 of 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Buttons Replacement: step 2, image 1 of 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Buttons Replacement: step 3, image 1 of 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Buttons Replacement: step 4, image 1 of 2 VTech Baby's Learning Laptop Buttons Replacement: step 4, image 2 of 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Buttons Replacement, Buttons: step 5, image 1 of 1
    • Using a Phillips #0 screwdriver remove the two 6.0mm screws.
  6. VTech Baby's Learning Laptop Buttons Replacement: step 6, image 1 of 2 VTech Baby's Learning Laptop Buttons Replacement: step 6, image 2 of 2
    • Lift up on the board and set it aside.
    • Movement of the board will be limited. Be careful not to damage the connection to the motherboard.
  7. VTech Baby's Learning Laptop Buttons Replacement: step 7, image 1 of 1
    • Remove each button and button contact.
2 other people completed this guide.
Christopher Kourmoulakis
412 Reputation
3 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2015 Member of USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,144
