VTech CS6719-2 Screen Replacement
  1. VTech CS6719-2  Screen Replacement, Battery: step 1, image 1 of 2 VTech CS6719-2  Screen Replacement, Battery: step 1, image 2 of 2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2  Screen Replacement: step 2, image 1 of 1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2  Screen Replacement: step 3, image 1 of 1
    • Unplug the battery input cable.
  4. VTech CS6719-2  Screen Replacement: step 4, image 1 of 1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2  Screen Replacement, Circuit Board: step 5, image 1 of 2 VTech CS6719-2  Screen Replacement, Circuit Board: step 5, image 2 of 2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2  Screen Replacement: step 6, image 1 of 1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2  Screen Replacement: step 7, image 1 of 2 VTech CS6719-2  Screen Replacement: step 7, image 2 of 2
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2  Screen Replacement, Screen: step 8, image 1 of 1
    • Remove the plastic screen.
Joshua Woodward
122 Reputation
1 Guide authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 386
