VTech CS6719-2 Charging Wire Repair
  1. VTech CS6719-2 Charging Wire Repair, Base: step 1, image 1 of 2 VTech CS6719-2 Charging Wire Repair, Base: step 1, image 2 of 2
    • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
  2. VTech CS6719-2 Charging Wire Repair: step 2, image 1 of 1
    • Use the spudger to separate the bottom from the top.
    • There are two clips, located top and bottom, that you have to compress with the spudger.
  3. VTech CS6719-2 Charging Wire Repair, Charging Wire: step 3, image 1 of 1
    • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
  4. VTech CS6719-2 Charging Wire Repair: step 4, image 1 of 1
    • Refer to How to Solder and Desolder connections How To Solder and Desolder Connections
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very hot.
  5. VTech CS6719-2 Charging Wire Repair: step 5, image 1 of 1
    • Heat up solder joint on the base unit where the charging wires are connected.
  6. VTech CS6719-2 Charging Wire Repair: step 6, image 1 of 1
    • Take a wire of solder and apply to joint on board to remove the extra solder.
    • Remove charging wire connection.
Josh Showalter
442 Reputation
3 Guides authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,546
