VTech InnoTab 2 Back Panel Replacement
  1. VTech InnoTab 2 Back Panel Replacement, Battery: step 1, image 1 of 3 VTech InnoTab 2 Back Panel Replacement, Battery: step 1, image 2 of 3 VTech InnoTab 2 Back Panel Replacement, Battery: step 1, image 3 of 3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Back Panel Replacement, Back Panel: step 2, image 1 of 3 VTech InnoTab 2 Back Panel Replacement, Back Panel: step 2, image 2 of 3 VTech InnoTab 2 Back Panel Replacement, Back Panel: step 2, image 3 of 3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Back Panel Replacement: step 3, image 1 of 3 VTech InnoTab 2 Back Panel Replacement: step 3, image 2 of 3 VTech InnoTab 2 Back Panel Replacement: step 3, image 3 of 3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Back Panel Replacement: step 4, image 1 of 2 VTech InnoTab 2 Back Panel Replacement: step 4, image 2 of 2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Back Panel Replacement: step 5, image 1 of 2 VTech InnoTab 2 Back Panel Replacement: step 5, image 2 of 2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
Roberto Valdes
302 Reputation
3 Guides authored
USF Tampa, Team S1-G85, Cagle Fall 2017 Member of USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 570
