VTech InnoTab 2 Backup Battery Replacement
  1. VTech InnoTab 2 Backup Battery Replacement, Backup Battery: step 1, image 1 of 3 VTech InnoTab 2 Backup Battery Replacement, Backup Battery: step 1, image 2 of 3 VTech InnoTab 2 Backup Battery Replacement, Backup Battery: step 1, image 3 of 3
    • The CR2032 compartment is located on bottom left corner on the backside of the device.
    • Unscrew the single 4 mm Phillip screw and slide the compartment cover off.
    • The 4 mm Phillip screw will not completely screw out of the cover.
  2. VTech InnoTab 2 Backup Battery Replacement: step 2, image 1 of 3 VTech InnoTab 2 Backup Battery Replacement: step 2, image 2 of 3 VTech InnoTab 2 Backup Battery Replacement: step 2, image 3 of 3
    • Gently remove the CR2032 battery with your fingers.
    • A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
Mark Lefcourt
201 Reputation
2 Guides authored
USF Tampa, Team S1-G85, Cagle Fall 2017 Member of USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 581
