VTech InnoTab 2 Camera Replacement
  1. VTech InnoTab 2 Camera Replacement, Battery: step 1, image 1 of 3 VTech InnoTab 2 Camera Replacement, Battery: step 1, image 2 of 3 VTech InnoTab 2 Camera Replacement, Battery: step 1, image 3 of 3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Camera Replacement, Back Panel: step 2, image 1 of 3 VTech InnoTab 2 Camera Replacement, Back Panel: step 2, image 2 of 3 VTech InnoTab 2 Camera Replacement, Back Panel: step 2, image 3 of 3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Camera Replacement: step 3, image 1 of 3 VTech InnoTab 2 Camera Replacement: step 3, image 2 of 3 VTech InnoTab 2 Camera Replacement: step 3, image 3 of 3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Camera Replacement: step 4, image 1 of 2 VTech InnoTab 2 Camera Replacement: step 4, image 2 of 2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Camera Replacement: step 5, image 1 of 2 VTech InnoTab 2 Camera Replacement: step 5, image 2 of 2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
  6. VTech InnoTab 2 Camera Replacement, Camera: step 6, image 1 of 3 VTech InnoTab 2 Camera Replacement, Camera: step 6, image 2 of 3 VTech InnoTab 2 Camera Replacement, Camera: step 6, image 3 of 3
    • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
    • The connection to the camera is located on top side of the devices motherboard.
    • Pulling the camera while the connection to the motherboard is still intact can cause damage to the circuit board.
    • Attach the replacement camera and lower the latch until a click sound can be heard.
Roberto Valdes
302 Reputation
3 Guides authored
USF Tampa, Team S1-G85, Cagle Fall 2017 Member of USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 459
