VTech InnoTab Max Battery Replacement
  1. VTech InnoTab Max Battery Replacement, Cover: step 1, image 1 of 3 VTech InnoTab Max Battery Replacement, Cover: step 1, image 2 of 3 VTech InnoTab Max Battery Replacement, Cover: step 1, image 3 of 3
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Battery Replacement: step 2, image 1 of 3 VTech InnoTab Max Battery Replacement: step 2, image 2 of 3 VTech InnoTab Max Battery Replacement: step 2, image 3 of 3
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
  3. VTech InnoTab Max Battery Replacement: step 3, image 1 of 2 VTech InnoTab Max Battery Replacement: step 3, image 2 of 2
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Battery Replacement: step 4, image 1 of 2 VTech InnoTab Max Battery Replacement: step 4, image 2 of 2
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Battery Replacement, Battery: step 5, image 1 of 1
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
  6. VTech InnoTab Max Battery Replacement: step 6, image 1 of 3 VTech InnoTab Max Battery Replacement: step 6, image 2 of 3 VTech InnoTab Max Battery Replacement: step 6, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
  7. VTech InnoTab Max Battery Replacement: step 7, image 1 of 3 VTech InnoTab Max Battery Replacement: step 7, image 2 of 3 VTech InnoTab Max Battery Replacement: step 7, image 3 of 3
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
  8. VTech InnoTab Max Battery Replacement: step 8, image 1 of 1
    • The battery is now fully disconnected.
8 other people completed this guide.
Jacob Schioppo
594 Reputation
4 Guides authored
USF Tampa, Team S5-G5, Lacy Spring 2017 Member of USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Members
10 Guides authored
10 Guide Comments
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - Reply
Where can we purchase a replacement battery
Frank Godon - Reply
Where can we buy a replacement battery
Frank Godon - Reply
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - Reply
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - Reply
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 84
All Time: 15,369
