VTech InnoTab Max Camera Replacement
  1. VTech InnoTab Max Camera Replacement, Cover: step 1, image 1 of 3 VTech InnoTab Max Camera Replacement, Cover: step 1, image 2 of 3 VTech InnoTab Max Camera Replacement, Cover: step 1, image 3 of 3
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Camera Replacement: step 2, image 1 of 3 VTech InnoTab Max Camera Replacement: step 2, image 2 of 3 VTech InnoTab Max Camera Replacement: step 2, image 3 of 3
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
  3. VTech InnoTab Max Camera Replacement: step 3, image 1 of 2 VTech InnoTab Max Camera Replacement: step 3, image 2 of 2
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Camera Replacement: step 4, image 1 of 2 VTech InnoTab Max Camera Replacement: step 4, image 2 of 2
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Camera Replacement, Camera: step 5, image 1 of 1
    • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
  6. VTech InnoTab Max Camera Replacement: step 6, image 1 of 2 VTech InnoTab Max Camera Replacement: step 6, image 2 of 2
    • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
    • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
  7. VTech InnoTab Max Camera Replacement: step 7, image 1 of 1
    • The camera is now removed completely removed from the device.
Jacob Schioppo
594 Reputation
4 Guides authored
USF Tampa, Team S5-G5, Lacy Spring 2017 Member of USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 652
