VTech InnoTab Max Cover Replacement
  1. VTech InnoTab Max Cover Replacement, Cover: step 1, image 1 of 3 VTech InnoTab Max Cover Replacement, Cover: step 1, image 2 of 3 VTech InnoTab Max Cover Replacement, Cover: step 1, image 3 of 3
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Cover Replacement: step 2, image 1 of 3 VTech InnoTab Max Cover Replacement: step 2, image 2 of 3 VTech InnoTab Max Cover Replacement: step 2, image 3 of 3
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
  3. VTech InnoTab Max Cover Replacement: step 3, image 1 of 2 VTech InnoTab Max Cover Replacement: step 3, image 2 of 2
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Cover Replacement: step 4, image 1 of 2 VTech InnoTab Max Cover Replacement: step 4, image 2 of 2
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
Alexander Bees
152 Reputation
1 Guide authored
USF Tampa, Team S5-G5, Lacy Spring 2017 Member of USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 864
