VTech InnoTab Max Screen Replacement
  1. VTech InnoTab Max Screen Replacement, Cover: step 1, image 1 of 3 VTech InnoTab Max Screen Replacement, Cover: step 1, image 2 of 3 VTech InnoTab Max Screen Replacement, Cover: step 1, image 3 of 3
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Screen Replacement: step 2, image 1 of 3 VTech InnoTab Max Screen Replacement: step 2, image 2 of 3 VTech InnoTab Max Screen Replacement: step 2, image 3 of 3
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
  3. VTech InnoTab Max Screen Replacement: step 3, image 1 of 2 VTech InnoTab Max Screen Replacement: step 3, image 2 of 2
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Screen Replacement: step 4, image 1 of 2 VTech InnoTab Max Screen Replacement: step 4, image 2 of 2
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Screen Replacement, Battery: step 5, image 1 of 1
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
  6. VTech InnoTab Max Screen Replacement: step 6, image 1 of 3 VTech InnoTab Max Screen Replacement: step 6, image 2 of 3 VTech InnoTab Max Screen Replacement: step 6, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
  7. VTech InnoTab Max Screen Replacement: step 7, image 1 of 3 VTech InnoTab Max Screen Replacement: step 7, image 2 of 3 VTech InnoTab Max Screen Replacement: step 7, image 3 of 3
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
  8. VTech InnoTab Max Screen Replacement: step 8, image 1 of 1
    • The battery is now fully disconnected.
  9. VTech InnoTab Max Screen Replacement, Screen: step 9, image 1 of 2 VTech InnoTab Max Screen Replacement, Screen: step 9, image 2 of 2
    • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
    • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
  10. VTech InnoTab Max Screen Replacement: step 10, image 1 of 3 VTech InnoTab Max Screen Replacement: step 10, image 2 of 3 VTech InnoTab Max Screen Replacement: step 10, image 3 of 3
    • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
  11. VTech InnoTab Max Screen Replacement: step 11, image 1 of 3 VTech InnoTab Max Screen Replacement: step 11, image 2 of 3 VTech InnoTab Max Screen Replacement: step 11, image 3 of 3
    Buy
    • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
    • Be careful not to tear the film when pulling.
  12. VTech InnoTab Max Screen Replacement: step 12, image 1 of 2 VTech InnoTab Max Screen Replacement: step 12, image 2 of 2
    • Once unclipped from the motherboard the screen should be entirely free from the device
4 other people completed this guide.
Jacob Schioppo
594 Reputation
4 Guides authored
USF Tampa, Team S5-G5, Lacy Spring 2017 Member of USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Members
10 Guides authored
5 Guide Comments
Where can I buy a screen
Damien Hennigan - Reply
Where can I buy a screen? Can't find any sites that sell the innotab Max screens.
i can not seem to find a replacement screen online, where can i buy one? Innotab Max from Vtech… HELP please..
fanny_muller - Reply
Hello, where can i buy a KIDICOM MAX Rose Screen. Our daughter here is broken!.thanks a lot!
hans.depre@gmail.com
Hans Depre - Reply
bonjour je cherche a raplasser l ecran du kidicom max car le mien ne salume plus pas merci
theobald - Reply
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 52
All Time: 5,598
